External Renderer not found
I dont know what happened But now I am getting a External Renderer not found error. I tried different Decklink ports, Decklink renderers, set to SDI output I've tried different frame rates and different resolutions.
I can't seem to get it to work.
I did search the forums and there were a few people that had this issue. I never found the solution though.
Can anyone point me to an answer in the posts or provide a solution if you know of one. Thanks guys!
Joined: 8/2/2020(UTC) Posts: 15  Location: Chicago Thanks: 2 times Was thanked: 2 time(s) in 2 post(s)
Try Removing an Re-installing BMD software, (Make take a couple re-boots) then launch vMix, That usually fixes it
