TBacker
#1 Posted : Thursday, September 9, 2021 11:29:53 AM(UTC)
TBacker
Before I add a feature request and get lit up for missing something....
Is there any way currently to perform a crossfade on data change for an image in GT Title Designer?
The fade transitions are not cutting it - they fade to transparent before fading in the new image. I tried playing with various combinations of delays, etc. but nothing works. It appears that image objects in GT can only cache one image at a time and, hence, can't crossfade as two different images would need to be in memory to overlap for a period.
#2 Posted : Thursday, September 9, 2021 1:52:24 PM(UTC)
The same applies for text , it animates out and then animates in and each can have a different animation
TBacker
#3 Posted : Thursday, September 9, 2021 2:04:56 PM(UTC)
TBacker
Correct. I understand that is the way it's working.
My point is I need a transition where there is no complete fade out before the new image fades in - a crossfade. Half way through the transition both images would be overlapped (aka 50% alpha each).
