rvhill55
#1 Posted : Sunday, September 5, 2021 9:14:40 AM(UTC)
rvhill55
Hi, folks.
I am setting up vMix for our church to stream our services. The Facebook Live stream drops within only a couple of minutes. I AM able to use vMix to produce the content with PowerPoint and a PTZ camera and stream using OBS that captures vMix the output screen. This configuration works very well, but is clumsy and I want to get vMix to do the streaming too. It seems that if I can run vMix and OBS and successfully stream then vMix should be able to do it alone. As I watch the vMix stream, the CPU and GPU percentages are nominal but the total CPU is very high. Watching the GPU performance shows a constant flow until it sharply pegs and then drops to zero. Stream is lost. Any ideas? Thanks.
Hardware:
AMD Ryzen 3 CPU
3.5 GHz Radeon Vega Graphics
GeForce 2GB
8 GB DDR4 (PC4-19200)
480 GB Solid State Hard Drive (Windows Hard Drive for performance)
Internal DVD Writer
22X Onboard 10/100/1000 Gigabit LAN Onboard
8 Channel Audio
Windows 10 Professional 64bit
GeForce Graphics Card
Network:
Spectrum Cable 100/10. There are no drops shown by Spectrum.
Babbit
#2 Posted : Sunday, September 5, 2021 10:41:11 AM(UTC)
Babbit
Was thanked: 26 time(s) in 20 post(s)
https://www.vmix.com/knowledgebase/article.aspx/295/what-to-look-for-when-purchasing-a-laptop-or-pc-for-vmix
That Radeon sticks out like a sore thumb. No reason to be running a Radeon and GeForce in one system. It will cause more harm than good. Ditch the Radeon and run the GeForce only.
Nvidia cards are a pretty concrete requirement for vMix, as noted on the page above.
thanks 1 user thanked Babbit for this useful post.
rvhill55 on 9/5/2021(UTC)
rvhill55
#3 Posted : Sunday, September 5, 2021 10:54:57 AM(UTC)
rvhill55
My knowledge of graphics cards it lacking. That sounds like a very good idea and something that I should be able to try. Thank you.
