pastorjim
#1 Posted : Monday, August 30, 2021 8:43:23 AM(UTC)
pastorjim
We are using VMix to stream our church services to Youtube and Facebook as well as our FM radio station.
The VMix computer and our radio automation computer clocks are synchronized.
Starting the feed to our radio automation machine is no problem.
However, since the service doesn't end at exactly the same time each week, I need a way to do the following:
When an "end credits" input starts (TransitionIn) in VMix, I need the VMix computer to send a command over our local network to a private ip address (our radio automation computer) on a user-defined TCP port that will trigger a process on that machine to play an audio "end credits" CART.
The text string I need to send over TCP is "Cart mF02" (without the quotes).
How can I get VMix to send a text string over TCP in response to a trigger?
Thank you!
Jim
#2 Posted : Monday, August 30, 2021 4:46:48 PM(UTC)
Trigger calls script (ScriptStart), script does TCP send (vb.net)
pastorjim
#3 Posted : Tuesday, August 31, 2021 1:54:44 AM(UTC)
pastorjim
I really appreciate the help. I've done some powershell scripting, but no vb.net. Could you give me an example of what the vb.net code would look like to accomplish this task:
Send the text:
Cart mF02
To the IP address: 192.168.128.102
Port: 5233
Thank you!
stigaard
#4 Posted : Tuesday, August 31, 2021 6:21:00 AM(UTC)
stigaard
Denmark
Try something like this...
Code:
' Message
Dim message as String = "Cart mF02"
' Client TCP socket
Dim client As New System.Net.Sockets.TcpClient("192.168.128.102", 5233)
' Get a client stream for reading and writing.
Dim stream As System.Net.Sockets.NetworkStream = client.GetStream()
If stream.CanWrite Then
   Console.WriteLine("Can write to socket")
   ' Translate the passed message into ASCII and store it as a Byte array.
   Dim data As [Byte]() = System.Text.Encoding.ASCII.GetBytes(message)
   ' Send the message to the connected TcpServer
   stream.Write(data, 0, data.Length)
   Console.WriteLine("Sent message to socket:")
   Console.WriteLine(message)
Else
   Console.WriteLine("Sorry.  You cannot write to this NetworkStream.")
End If
thanks 4 users thanked stigaard for this useful post.
doggy on 8/31/2021(UTC), pastorjim on 8/31/2021(UTC), studiodelta on 12/11/2022(UTC), ryanlehms on 5/15/2025(UTC)
pastorjim
#5 Posted : Tuesday, August 31, 2021 9:15:59 AM(UTC)
pastorjim
Thank you very much!
ryanlehms
#6 Posted : Thursday, May 15, 2025 1:45:38 AM(UTC)
ryanlehms
This took me way too long to figure out, so I figured I would share it for anyone else who stumbles across it. To add a carriage return, use Environment.NewLine in your script. I needed it to send commands to the ZEN NDI Router. And don't forget to close your streams.
Code:
' Message
' Client TCP socket
   Dim data As [Byte]() = System.Text.Encoding.ASCII.GetBytes(message & Environment.NewLine)
   Console.WriteLine(message & Environment.NewLine)
Else
End If
Call stream.Close()
Call client.Close()
thanks 1 user thanked ryanlehms for this useful post.
MDB on 10/31/2025(UTC)
