Joined: 8/28/2021(UTC) Posts: 1  Location: Kuala Lumpur
It would be nice if you could start numbering triggers for a certain input, then have a trigger to enable/disable a numbered trigger. I think it's pretty self explanatory
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: NeonFaith  It would be nice if you could start numbering triggers for a certain input, then have a trigger to enable/disable a numbered trigger. I think it's pretty self explanatory Can you give a few practical use examples pls
