I don't know about anyone else, but I keep leaving the keyboard enabled on browser inputs. It would be nice to have an alert that warns you that the keyboard is enabled after x minutes of no new key presses.
Even better yet, it would be nice if the keyboard control for browser windows would automatically disable after a period of inactivity. Ideally, that period of inactivity could be specified in the settings with "never" being an (default?) option to retain the same functionality as vMix currently has.
Use one of the browser specific shortcuts maybe ?
I suppose it may be possible to script disabling the keyboard control after some time, but as far as I know, there is no way to trigger an alert in vMix.
Or is there some other shortcut you are referring to?
Joined: 8/25/2021(UTC) Posts: 5   Location: Belgrade Was thanked: 1 time(s) in 1 post(s)
For now there is only way, add triger BrowserKeyboardDisable and set delay to 600000 (for example).
I know to that's not optimal solution but you can't do anything more for now.
Yup, that's what I figured. I actually meant to post this in feature requests. If a mod could move it, that would be great.
