tbarden
#1 Posted : Monday, August 23, 2021 11:19:27 PM(UTC)
tbarden
We have a black box theater that fit up for multi-camera video capture / streaming using vMix 4k. We are trying to figure out how best to route audio from our digital mixing board to our vMix workstation and NDI Audio Direct seems like it would be a good tool. However, we can't get vMix to recognise the plug-ins. Other VST3 aware applications see it find but not vMix. I assume it's a directory problem.
vMix documentation says that vMix will find 64 bit vst3's and it does seem to find those that are in the "Program Files/Common Files/VST3" directory. However, the NDI VST3s are nested in subdirectories within that directory and vMix doesn't recognize them.
Is there a workaround? If not what's the plan to fix?
