tom@24bit.io
#1 Posted : Friday, August 20, 2021 2:35:41 AM(UTC)
tom@24bit.io
I have a requirement to make vMix change stream keys based on the time of day. The stream keys will be in a Google Sheet.
How do I access the datasource values (strings) within the script?
So far I have:
API.Function("DataSourceSelectRow",Value:="Stream_Key_Test,Keys,0")
API.Function("StreamingSetKey",0,"test123")
And I need to replace "test123" with a variable that contains the actual text stored in the second column of the spreadsheet at row 0.
Many thanks
#2 Posted : Friday, August 20, 2021 5:30:52 AM(UTC)
So far I have:
Many thanks
One puts the value in a title and read with script from there or the script access the data source file directly (preferable XML source)
Check out "scripting for dummies" post and how to read text from a title in the helpfiles
