BillPerry
#1 Posted : Sunday, August 15, 2021 8:50:11 PM(UTC)
BillPerry
Sewing Machine Swallowing The Fine Fabric - What to Do?
When you are sewing a good and expensive fabric but suddenly the sewing machine has begun to eat your fabric, what will you do? I understand your mood now. The new sewists will panic and worry. In this article, we have listed some effective solutions to prevent your machine from eating fabrics.
In the best sewing machine for beginners, the settings will make them not eat fabrics anymore. You can check this post Top Sewing Machines For Beginners UserPostedImage if you are looking for a good basic sewing machine to learn sewing! Keep reading!
How to fix when sewing machine swallows fabric
Sewing Machine Eats Fabric - Reason 1
First, the reason that your sewing machine eats fabrics is because of stitch length. This happens with new sewists or even an expert. You need to understand the weight and nature of the fabric. After that, you will decide on the needle and thread for your project. The important thing I want to say is that you have to put the sewing machine according to the fabric. If it's good and expensive fabric, let's pay attention to the seam length.
Once you have the wrong seam length, there will be trouble in the middle of the stitch, and your machine will eat the fabric. Moreover, the needle will damage the appearance of the fabric. Therefore, you must always check the settings of the sewing machine before you start a project!
Sewing Machine Eats Fabric - Reason 2
Next, you need to pay attention to the maintenance and cleaning of your basic sewing machine. If your best sewing machine for beginners UserPostedImage has ever eaten fabric, you must clean it before you want to start a project with new fabrics. On the manual of your machine, there will be full steps in the process of removing the plate for cleaning. You simply need to read and follow these steps!
After cleaning the plate in the sewing machine, you can start your project without problems!
This is one of my favorite solutions: Cover the Opening. The problem of eating cloth has been solved by this method in case you don't want to buy a new stitch. With some stitches that have expansion holes, your sewing machine may start eating fabrics. Then the thread will be broken and your whole project will become a mess.
Avoid sewing machine swallowing fabric
First, you must use tape to cover the extension of the plate. You use tape to close the opening. Once you close it, you can sew comfortably without thinking that your sewing machine can eat fabrics anymore! If you are using the best coverstitch machine then you don't have to worry about this problem.
Next, chain stitching. This is a common solution that people often use to avoid sewing machines to eat fabrics. This solution is especially effective with smooth fabric. With chain stitching, you can continue sewing without raising the footer. But this is not a simple technique.
You should prepare a raw patch and test it once. Check the settings and performance of the UserPostedImage best basic sewing machine before you start a project! If you don’t know where to buy the best sewing machine for beginners or first-time users, visit our website at CraftsSelection.com to get the best deals on sewing machines and crafting machines.
