bcrotaz
#1 Posted : Saturday, August 14, 2021 9:03:28 PM(UTC)
bcrotaz
Rank:: Newbie
Plugin API should allow push and pull feeds. I have a feed for example on a websocket which is receiving data pushed from remote sources.
Suggest a plugin is a .Net class implementing a VMix interface IVMixDataSource (similar to xaml template plugins) and a class attribute [VMixPlugin("vendor-name", "plugin-name")] which populates the data source menu. Attributes could also be used to tell VMix what config fields are available in the plugin to populate a VMix config page.
To register a plugin as a data source,
1. Open the plugin dll in VMix.
2. VMix looks for all public classes that implement IVMixDataSource
3. VMix adds the plugin to its registry under a sub group for vendor-name (to avoid name clashes)
A starting point that would work for table style data - the same concept could be used for named data rows.
Code:
IVMixDataSource {
  // init gets called by VMix on startup to send a push interface to the plugin
  void init(IVMixPushDataSink pushDataSink, IDictionary<string, string> config);
  // functions to pull data from plugin
  int rowCount {get;}
  IDictionary<string, object> getRow(int row);
  // VMix can use these to subscribe only to rows that are needed on air
  // null means all
  void subscribe(int? row = null);
  void unsubscribe(int? row = null);
IVMixPushDataSink {
  // plugin can push data to VMix
  void publishRow(int row, IDictionary<string, object> row);
hakan_forss
#2 Posted : Friday, August 20, 2021 8:32:19 PM(UTC)
hakan_forss
Rank:: Advanced Member
Sweden
+1
