fluozh
#1 Posted : Saturday, August 14, 2021 9:20:15 AM(UTC)
fluozh
Japan
Was thanked: 13 time(s) in 10 post(s)
Source drop in statistics increases dropped frames when it did not receive frame even NDI framerate is slower than vMix project itself.
e.g. vMix has 1080p59.94, my NDI cam has 1080p29.97.
So dropped frame increases 30 every second even connection is fine.
I'm using vMix for investigating NDI connection stability.
Also, NDI application like ScreenCapture, vMix Desktop capture does not send any data when its "freeze". It also causes source drop.
zenvideo
#2 Posted : Saturday, August 14, 2021 7:25:58 PM(UTC)
zenvideo
What did you expect the stats to show you under those circumstances?
fluozh
#3 Posted : Sunday, August 15, 2021 6:59:56 PM(UTC)
fluozh
Japan
For me, I need to know if its dropping because of performance(e.g. network issue) or framerate(59.94 - 29.97).
So it should be 0 drops if connection is fine, and increase source drop numbers if problem occurs(e.g. packet loss etc).
