john30120
#1 Posted : Sunday, August 8, 2021 8:09:35 AM(UTC)
john30120
Some time ago I was able to start vMix from an icon or BAT file calling ....MyPreset.vmix. Now vMix starts but the Windows Explorer pops up and the process stops until the Windows Explorer is closed. Then vMix proceeds to load the Preset's attributes and the program starts normally.
No idea why Windows Explorer decided it needed to open and it is annoying because it now requires operator action instead of the automatic startup I would like.
Any ideas??
Papo
#2 Posted : Sunday, August 8, 2021 10:48:50 AM(UTC)
Papo
Peru
I don't know what your bat was, or what its code was, but you tried creating a direct access to your preset file, it should open vmix with its preset, or there are more things it should do .. translated by google
#3 Posted : Sunday, August 8, 2021 6:43:15 PM(UTC)
Sure you are not missing a file within the preset ?
