Error sequence of cams does not change, needs to restart vMix
Joined: 3/3/2021(UTC) Posts: 32   Location: São Paulo Thanks: 1 times Was thanked: 12 time(s) in 5 post(s)
Hello dear.
I do not know if all users have this problem but even in version 23 we had the same situation: I open the Instant Replay settings and select the sequence of the cameras, for example: DTV: 2, 3, 4, 1, 5, 6 Replay: 2, 3, 4, 1, 5, 6 (same sequence equal to DTV). However, when viewing the Instant Replay multview the sequence remains the last that was used. At that time it only changes the sequence if I restart VMIX, and at the moment they are doing other operations in VMIX and can not be restarted ...
Could you analyze and give me a solution or if it is the case, correct in VMIX?
Thanks.
