You have been a member since:: 12/4/2020(UTC) Posts: 1
This would be great, since vMix is driven on INPUTS.
EXAMPLE: If I build a virtual input, which usually starts at the end of your assets, then I want to move that new "INPUT" look to input 1...Could there be a swap input function? So it doesn't push all the other assets that I have lined up there after out of sync to my show build.
Just a thought.
