Stream end abruptly with failed to update the header
Joined: 6/9/2020(UTC) Posts: 3  Location: FORRESTFIELD
Has anyone solve this error: Stream end abruptly with failed to update the header
FFMPEG1.Exited frame= 80 fps= 53 q=32.0 size= 503kB time=00:00:09.36 bitrate= 440.4kbits/s speed=6.22x frame= 95 fps= 47 q=31.0 size= 567kB time=00:00:09.87 bitrate= 470.6kbits/s speed=4.92x frame= 110 fps= 44 q=31.0 size= 642kB time=00:00:10.36 bitrate= 507.4kbits/s speed=4.13x frame= 125 fps= 41 q=32.0 size= 786kB time=00:00:10.87 bitrate= 592.0kbits/s speed=3.61x frame= 140 fps= 40 q=32.0 size= 854kB time=00:00:11.39 bitrate= 614.4kbits/s speed=3.24x frame= 155 fps= 39 q=32.0 size= 930kB time=00:00:11.88 bitrate= 641.1kbits/s speed=2.95x frame= 170 fps= 38 q=32.0 size= 1005kB time=00:00:12.39 bitrate= 664.7kbits/s speed=2.74x [tls @ 048733e0] Writing encrypted data to socket failed av_interleaved_write_frame(): I/O error Last message repeated 1 times [flv @ 04879920] Failed to update header with correct duration. [flv @ 04879920] Failed to update header with correct filesize. Error writing trailer of rtmps://live-api-s.facebook.com:443/rtmp/10158120764280846?s_bl=1&s_psm=1&s_sw=0&s_vt=api-s&a=AbzhpvvY162C6SIn: I/O error frame= 184 fps= 37 q=33.0 Lsize= 1143kB time=00:00:12.86 bitrate= 728.1kbits/s speed=2.58x video:1129kB audio:4kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.960262% [tls @ 048733e0] Writing encrypted data to socket failed Last message repeated 1 times [tls @ 048733e0] Failed to send close message [aac @ 0487e840] Qavg: 65536.000 Conversion failed!
