BenC
#1 Posted : Saturday, July 24, 2021 2:23:45 AM(UTC)
BenC
South Africa
Dear Martin and others
I have a very complex preset with over a hundred inputs.
vMix is now dropping all audio on a bunch of my main inputs (NDI, SRT) between PRE and POST.
I dont have any gain, plugins, gates etc enabled. The audio is clearly visible in PRE in the mixer, and missing in POST.
So tragic for me as I have a big production tomorrow.
If I bring the source in again using the same input, the problem persists.
If I bring the input in again anew (as a new input) it is solved. But then I lose all the shortcuts and scripts that were pointing to my input. (That's hundreds).
Please help!
BenC
dmwkr
#2 Posted : Saturday, July 24, 2021 2:54:26 AM(UTC)
dmwkr
Check if in the Channel Matrix the channels are routed to M bus.
