DailyRacquetball
#1 Posted : Friday, July 16, 2021 12:57:10 PM(UTC)
DailyRacquetball
In my vMix layout, I have an input window that works for my instant replay.
I click on the -5 and then on the play buttons and get the exact results I need.
I would like to automate this with an Elgato Streamdeck, so that I don't have to switch tabs and click on the specific input window, and then the -5, and then the play.
Has anyone completed these exact steps as a vMix shortcut or as an Elgato Streamdeck shortcut?
(There are too many instant replay shortcuts and none of them are named anything like the buttons in the UI, so I have no clue where to start to get where I need to go.)
Thanks in advance for any advice you can offer.
#2 Posted : Friday, July 16, 2021 5:13:06 PM(UTC)
Many argue there are not enough LOL
ReplayMarkInOut and Value = time
ReplayPlayLastEvent
Combine them under the same key
#3 Posted : Sunday, July 18, 2021 10:44:41 PM(UTC)
@ DailyRaquetball
Doggy is correct in that there are no Shortcuts specific to the -5 and -10 buttons in vMix, but rather, just the single customizable Shortcut “ReplayMarkInOut” that allows you to set how far back in seconds you want.
Essentially, the OUT (or end) point is determined by when you push the button and the IN (or start) point will be back whatever number of seconds you select for your Value.
gorbva
#4 Posted : Monday, October 18, 2021 9:24:42 PM(UTC)
gorbva
Kazakhstan
Just install Bitfocus Companion over original SteramDeck software and you can do more.
#5 Posted : Monday, October 18, 2021 9:48:39 PM(UTC)
But what if you don't need/want to do more and keep it KISS ? ;-)
Then again i do not have Stock in Companion ;-)
Radiotvpat1982
#6 Posted : Thursday, October 21, 2021 6:24:17 AM(UTC)
Radiotvpat1982
Was thanked: 15 time(s) in 11 post(s)
Slightly off subject here but I wish VMIX had a "Shortcut Record" feature similar to what Tricaster, Ross and BMD have to where you can just simply record a button(s) push on the UI and have those shortcuts being saved and assigned in a certain way or code.
I know when I first started using VMIX I was also very confused as to what the slight difference is from shortcut to shortcut. It certainly would simplify the shortcut/trigger process for automation.
This came to mind when I was trying to map the -5 and -10 buttons so VMIX on my control surface. I'm sure there are a lot of other examples, especially in instant replay.
An official automation guide with a brief description of each shortcut would also be valuable.
