Joined: 12/20/2017(UTC) Posts: 30  Location: Raleigh, NC Thanks: 7 times
I just installed VLC for vMix, and it doesn't create any shortcuts in the Start Menu. I had to find the EXE and create a shortcut for it. It even installs into ProgamData, not the normal Program Files folder. Is this normal?
