Joined: 8/2/2020(UTC) Posts: 15  Location: Chicago Thanks: 2 times Was thanked: 2 time(s) in 2 post(s)
Finally, a solution !
liminalet.com
Been testing it for a while now....brilliant stuff
Downside: You WILL Need macOS to run it:(
It's looking like a really great solution but after a few hours of playing with it, i am struggling to get a decent quality return video feed from vmix to zoom. Its very stuttery and terrible quality.
I have tried the following methods Im using NDI 5 tools (virtual input) taking vmix out and using it as zoom control laptops camera input to zoom. Ive also tried using and extended monitor with studio monitor open, again with vmix output and sharing my screen. the issue here is the zoom callers are not very out of sync and stuttering.
Im using a pro zoom account and all systems are up to date.
Any advice would be very welcome.
Try 720p on 4 feeds, we found that works great, for more than 4 we knock it down to 360 and create a gallery in vmix
solves a major problem of folks lining u with remade GFX overlays
 1 user thanked D.R. Lynn for this useful post.
Too bad it's mac only...
Any idea if a "cheap" macmini from 2017 or 2018 or a used Macbook would be enough to run it (4xHD + 1 gallery?)?
If this work as advertised this is really useful.
Best, Eric
Joined: 3/26/2020(UTC) Posts: 23   Thanks: 4 times Was thanked: 3 time(s) in 3 post(s)
I've had great success with this app...except for the fact that I can't get rid of the participant's names. I've reached out to the developer and they know of the issue and are in the process of trying to fix.
Joined: 2/8/2021(UTC) Posts: 6  Location: Washington, D.C. Was thanked: 36 time(s) in 3 post(s)
Originally Posted by: tcconway  I've had great success with this app...except for the fact that I can't get rid of the participant's names. I've reached out to the developer and they know of the issue and are in the process of trying to fix. Hey! Glad to hear you are having a good time with our app. The next release will have a little toggle button for the names, and we can send the beta release with that feature for any urgent needs.
Best, Eric That should work fine, reach out to my team though if you have trouble!
I'm using ZoomISO for camera feeds into vMix and it's a great workflow. But I'm having a problem with the ISO feeds having a red tint once they are in vMix. The issue is compounded on the program return feed - vMix output via NDI to the MAC -> NDI virtual Camera -> ZoomISO.
Anyone else seeing this?
I'm running a MAC Pro Late 2013. Big Sur 11.6 ZoomISO NDI5.
I would try the ZoomISO 4 version, vMix is out-of-the box Vmix 4.x
Ah, that's somthing I hadn't event considered. Thanks.
