EGSiegel
#1 Posted : Thursday, June 17, 2021 5:58:08 AM(UTC)
EGSiegel
I do woodworking demos...
I would like to put a title overlay on my presenter camera for when my demonstration starts. I know I can put the title on a layer and a trigger to remove it after 20 seconds.
is it possible to only display that layer (title) the 1st time that camera is selected during a demonstration? I really don't need my name coming up every time I go to the front camera :)
Thanks is advance for your advice
#2 Posted : Thursday, June 17, 2021 5:03:15 PM(UTC)
Just do it manually, sometimes going for automation makes things more complex than they really are...
OR
create a virtual input of your presenter's camera, set your overlay on it and only use this input the first time
OR
you can use your title as a layer in a multiview for the presenter's cam and use the "MultiViewOverlay" command to make it disappear as long as you do not toggle it on again
EGSiegel
#3 Posted : Friday, June 18, 2021 5:02:51 AM(UTC)
EGSiegel
are you saying that if you put the title on a layer in your camera input and have a trigger that toggles it off after 30 seconds....it will stay off even if you move to another input and come back to the 1st? That would work for me.
