I am using an ip PTZ camera that outputs a rtmp stream. Using a previous version of vmix I was able to access the rtmp stream using the vlc plugin, but now I just get a blank screen. When I select the stream for input I get a picture for just a second and then it stops.
As a work-around, I am using Internet Explorer windows to display the rtmp streams and then doing screen captures to get it into vmix.
Any idea what I can do to fix this?
