Joined: 5/11/2020(UTC) Posts: 13  Location: Los Angeles Thanks: 2 times Was thanked: 1 time(s) in 1 post(s)
I recently came with an idea of do like a live "news" on my show. So, my idea is I'm doing my original show, then I go to a quick commercial break, I open my green screen background behind me and I came back live with green screen.
Every time that I do this, I need go to my cam settings, apply the Chroma Key and also do some small color adjustments. I would love to have all of this ready to go, that's why I would love to "duplicate" my camera and have one of them "clean" and the other one with the chroma key and color correction activated.
I tried add a BLANK and add there the camera but the Chroma Key parameters aren't working.
Any solution for this? The other option that I'm thinking is create some kind of shortcut to activate/deactivate Chroma Key and Color Correction on the webcam.
Thank you!
Joined: 10/6/2020(UTC) Posts: 98  Was thanked: 21 time(s) in 21 post(s)
I think you can do what you want by creating a Virtual Input from your original camera source. Then you can add your chroma key and other effects to the virtual copy while leaving your original camera input unmodified, and you can switch between the 2 inputs as though they were different sources. In the settings window of your camera source, you'll find a 'Create Virtual Input' button.
