Feature Requests
Save Outputs/Fullscreen settings per document
Thanks: 16 times Was thanked: 11 time(s) in 9 post(s)
Hi I currently have a couple of Vmix use cases - where I need different fullscreen outputs depending on the application, currently (as far as I can tell) the Full Screen assignments and output assignments are global so need to be reset each time I load the template for each case. It would be great if we could move these to the document level....
Maybe it wont work as Windows screen numbering seems to be rather abstract, one day my target screen will be given number 1, another 2, another 4 at the OS level - but thats another issue.
Feature Requests
