tk421
#1 Posted : Sunday, June 6, 2021 1:27:34 AM(UTC)
tk421
Views messages in topic : 11
Canada
Was thanked: 11 time(s) in 3 post(s)
I've written a very small program to make adjustments to a vMix countdown time. The main function is to adjust a clock to an exact time, ex/ 23:48. I've been using it with a num pad from a second machine (not required) on the network, which gives very quick and fine control of the time as I can keep the program in focus. With an xkeys I believe you could direct input directly to this without keeping focus; I'm not 100% on that one though.
Download for windows and mac from here - One Drive Folder
Github is here - https://github.com/dlamon1/vMixClocker
Enter your time with a period separating hour/minute/second; as follows:
12 - will give you 00:00:12
23.34 - will give you 00:23:34
17.34.23 - will give you 17:34:23
