garci66
#1 Posted : Wednesday, September 3, 2014 7:02:11 PM(UTC)
garci66
I was using a multi-view source using a PNG as the background and then two overlays, one of which is a desktop capture. Both sources (a camera and the desktop capture) were transformed with perspective using the position controls of the sources in the overlay. The result is that both overlayed images look very very aliased when scaled.
Any ideas what might be causing it? This is on Vmix13. Im trying to attached a capture of the ouptut.
garci66 attached the following image(s):
