NDI
NDI output from vMix not visible in NDI studio after upgrade
Joined: 12/17/2020(UTC) Posts: 4  Location: Bruxelles
I am trying to get the NDI output from vMix in my laptop via NDI webcam input to use in meet or Zoom It was working fine last week but does not work anymore. The only change is vMix upgrade 24.0.0.58 as far as I know. The computer with webcam Newtek input detect the vMix source but the video is black On the other hand, adding a PTZ camera as a NDI source works...
Any advice ?
Joined: 4/23/2017(UTC) Posts: 1,454  Location: Germany Thanks: 3 times Was thanked: 192 time(s) in 172 post(s)
Can you check with Studio Monitor App.
Joined: 8/2/2013(UTC) Posts: 1,098   Location: Fairhope, Alabama USA Thanks: 587 times Was thanked: 202 time(s) in 168 post(s)
Works fine here. Sometimes NDI video takes a moment or two to populate, so it could just be a delay.
Also worth noting... many people say there have been no changes to their PC except a newer version of vMix. May be true, may be not true. If Windows updates in the background, it is possible that many, many changes have taken place.
And remember, sometimes updating Windows manually will fix a lot of problems.
- Tom
The past WE,I produced a live concert with 5 cams, all over NDI. No problems, no issues. Just flawless. And I'm on the latest W10 and vMix.
Thanks all for your suggestions.
I finally succeed to have the NDI vMix Program in the NDI webcam input, but without understanding exactly what the problem was... @ Mavik I have check with studio monitor with the same results at that time, Birddog PTZ visible but not the vMix program. I am using a Cisco switcher (for PPoe power supply) and guess the issue is related to this device. I got different results if I start NDI tools before starting vmix etc. I will do more test today. The initial plan was to connect Zoom or Msft Team on a laptop via NDI (in case the client does not agree to use vMixCall) I will now try to install the Team program directly on the vMix desktop and manage everything on the same computer.
NDI
