good evening everyone. hope someone help me. I bought a zowietek ptz and now I would like to be helped with the configuration. Can I connect it via hdmi and control it from vmix version 4 pro? alternatively can i buy a joystick for remote control? If so, which one? I also want to know if I can connect it directly via lan, without switch. I mean directly to the pc with ethernet cable. thank you
