parkmedia
#1 Posted : Wednesday, May 12, 2021 11:08:27 PM(UTC)
parkmedia
Spain
Hello, i'm wondering if it is possible to have more than 2 external output in Vmix.
I have a decklink duo 2, and what i need is to output fill&key+output1+output2. I have no problems with fill&key outputs, everything works fine.Also if i want another external output i can do it. The thing is that i want to use the last free output from my DL Duo2 as another external output in Vmix.I mean, i want to use more than 2 external output at the same time. Is that possible? how should i set the Vmix???
Thank you to all!
Vince Beck
#2 Posted : Thursday, May 13, 2021 2:48:13 AM(UTC)
Vince Beck
Only though NDI. You could get some NDI > SDI converters to make things a bit more reliable.
And of course, you can use a few Fullscreen outputs VIA your graphics card, which also happen to have less latency but are more prone to dropping frames.
thanks 1 user thanked Vince Beck for this useful post.
parkmedia on 5/13/2021(UTC)
