NYCshow
#1 Posted : 4 years ago
NYCshow
I'm scripting a "StartPlayList" command to - as you would expect - start a playlist.
However, there are times during the production that I want to stop and restart the playlist at a desired item inside the playlist. In the playlist window I would select "Begin from Selected Item" and then restart the playlist from there. But there seems to be no way to set this up in shortcuts.
First, I cannot set the "begin from selected item" programmatically. So I just do that manually by clicking the checkbox. But even when it is checked, and then I run the "StartPlayList" command, it always begins from the top of the playlist instead of the selected item. It doesn't 'honor' the checkbox.
Is this a bug or a feature?
As an aside - I'd LOVe the ability to toggle the "Begin from selected item" box and the "Manual Mode" box programmatically!!
Thanks for your thoughts.
Phil
