I would like to display verses during live feed. Is there an easy way to do this ?
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 319 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: craig  I would like to display verses during live feed. Is there an easy way to do this ? Have you searched this forum and checked the vMix knowledge base ? lots of info here too https://letmegooglethat.com/?q=vmix+bible+verses
Joined: 7/1/2020(UTC) Posts: 6  Location: Glasgow Thanks: 1 times
The other option (ie, other than using titles and manually typing or copying from BibleGateway/similar) would be to use some form of lyric/scripture presentation software and import that into vMix either via desktop capture, web browser or NDI from another computer. There are a tonne of options for this available.
You’ve had one of those days. You know 'em. The kind where you wake up late and have nothing to wear to work jcpenney kiosk. Once at work, your boss is on your case for a project you found out about just this morning.
Joined: 5/19/2017(UTC) Posts: 105   Location: The Netherlands Thanks: 16 times Was thanked: 36 time(s) in 24 post(s)
I'm working on a web application that neatly integrates with the vMix titles. As soon as I think it's ready I'll post it on the 3rd party section of this forum.
Note, I'll use public domain bibles via api.bible as main source. Licensed bibles can be unlocked by getting permission from the publisher
 1 user thanked guidogast for this useful post.
Joined: 11/7/2018(UTC) Posts: 7  Location: Muncie, Indiana Thanks: 2 times Was thanked: 1 time(s) in 1 post(s)
As with Joeboe we use Bible Show, it has NDI out from the software and I bring it into vMix with NDI. Have Bible Show on second computer & my wife runs it. We've used it for over a year and a half with no problems, and best of all it's FREE.
We use www.VerseCAST.app as our main church presentation software that runs on a phone (Android, iOS). You can add a subtitle screen to vMIX - it is just a web browser layer with the URL that the APP provides. More info can be found here https://www.versecast.app/streaming
Joined: 11/27/2023(UTC) Posts: 136  Thanks: 10 times Was thanked: 10 time(s) in 10 post(s)
Use 'Bible Show', bring it into vMix via NDI, as it has NDI out ... you can use Bible Show on second computer, I use it on the same PC with a second monitor ... and best of all it's FREE
