MartLeib
#1 Posted : Thursday, April 29, 2021 8:13:00 PM(UTC)
MartLeib
Estonia
Has anyone ever needed to get input resolution and/or fps over the API, is it possible even? I'm trying to create a little helper which detects if you have mixed resolution or framerate input cameras in the project or inputs with lower resolution than output and also output this info on the OLED above the SDI connector.
Before going the DeckLink SDK route I wanted to check vMix side as well.
