Joined: 10/27/2020(UTC) Posts: 38  Location: Porto Alegre Thanks: 13 times Was thanked: 2 time(s) in 2 post(s)
Hey guys,
Does anyone know if there is any way within vMix to be able to view more "BUS" channels or just via WEB / UTC / PAGE BUILDER ...?
I miss having more "bus" showing up to make the settings. Remembering of course, it is inside the insert, because only "M / A / B" appears
Thanks!
Joined: 7/28/2019(UTC) Posts: 351  Location: Santa Rosa Thanks: 1 times Was thanked: 53 time(s) in 51 post(s)
Not sure I quite get the question. I imagine you know that right clicking on the AB buses will reveal the others?
Originally Posted by: Vince Beck  Not sure I quite get the question. I imagine you know that right clicking on the AB buses will reveal the others? Yes, I know that when you click on, the other BUS will appear. But my doubt is that there is a way, to appear directly, without having to use the right button of the mouse, being, therefore, faster to have access, even more when using more than 3 BUS.
I don't believe there is.
Of everything I have researched and revised the software, I just found it in other ways, but inside it, directly on the input on, M / A / B appears, unfortunately there is nothing. Of course, when opening the input settings, all BUSs appear, but I would like to be something more practical, without having to use a UTC / PAGE BUILDER or other resource for that. I believe that this would not be useful only with me, but with many other people.
Hello, I agree with the original post. I use many times more than two buses.
It is hard to have an overview wich one is active for an specified input. At the right side of the volume fader, hopefully there is enough space to arrange the buses from A-G in a column.
This is helpfull for having a better overview of the current status and enables you the active/deactivate in a much better speed the buses.
Timo
Joined: 7/14/2020(UTC) Posts: 27  Location: Warwickshire Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
