Joined: 11/2/2020(UTC) Posts: 7  Location: Lier Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
Hi to anyone out there using the "Behringer Xtouch Compact" controller in combination with Vmix.
- Who has the best shortcut and Activator files and wants to share them with the community? - I have programmed pretty good "shortcuts and Activator files" but I'm missing some bits. I hope you can help me with this. Once my programmation is final I will be more than happy to share a download link for all of you.
I'm missing:
Activators: - Audio Auto (this is the Follow input function in vmix). I can't find the correct activator to lite the LED button on the controller - I'm missing the activator to set the light around the rotary buttons that I use for panning left/right.
Other general questions: - what do you use the rotary buttons 9-16 for? I'm using them for Bus volume. - Is it possible to use rotary buttons for the audio gain of an audio channel?
please share all your thoughts about programming shortcuts and activators for the Behringer Xtouch Compact.
many thanks, Gert Belgium
