NDI
NDI Tools 4.6.3 Virtual/Webcam Input - Run at Windows start - ISSUE
When installing NDI Tools 4.6.3 on Windows you are prompted to select components. If you select Webcam Input and Run at Windows start, the installer creates a task in Task Scheduler called NDI_VirtualInput.
Unfortunately, this task is set to terminate after 3 days (Windows default). So if you are finding your Webcam input into Zoom or Meets etc. suddenly closes with no error in Event Viewer, check how you are starting it.
To fix, right click on the task in Task Manager, select properties, settings, and untick 'Stop the task if it runs longer than'.
Joined: 4/23/2017(UTC) Posts: 1,494  Location: Germany Thanks: 3 times Was thanked: 199 time(s) in 179 post(s)
NDI
