Joined: 11/9/2020(UTC) Posts: 20  Location: Bogota Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Hi again,
I have the following scenario and I'd like your inpur.
I created a "list" with zppers and dound effects which I've added shortcuts to automate some tasks like
AudioOn <List> SelectIndex from <List> Restart Current Item Play Current selection
I need to MUTE my mic while the promo plays, even though I cna do that with a shortcut that AudioOff on the Mic channel, how do I make it AudioOn again? Is there such feature?
I've tried to do it with Triggers, no luck, ss you may know, when you use the Play action, item will sit into preview window so none of the Triggers on the playlist properties work OnOverlayIn,OnTrasitionIn, there should be OnPreview or something like that so we could work on stuff that's on the preview window. Or am I not looking in the right place?.
I did this with a VIDEOS List which merges its conetnts and using triggers I get the desired behavior.
Thanks again folks.
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
Instead of playing the audio list, you could bring it in as an Overlay. Use the OnCompletion trigger to turn off the overlay and turn on the mic.
Originally Posted by: dmwkr  Instead of playing the audio list, you could bring it in as an Overlay. Use the OnCompletion trigger to turn off the overlay and turn on the mic. Man thanks, that was the one, so many ways to skin a cat, reduced my shortcuts from 5 to just two: OverlayInput4 <List>, SelectIndex <#>, on the List's Triggers I added: OnOverlayIn > AudioOn the list, AudioOff my Mic, OnCompletion > AudioOn my mic, OverlayInput4Off. That's my approach, any thoughts, although it works.
