Automated loop between two cameras?
This evening we are going to livestream a shot of the cross in our church for the Easter Vigil. I wanted to set it up so that the livestream alternates between two cameras every couple of minutes. I tried setting up a trigger for OnTransitionIn and a fade to the other camera after 1000ms as a test but it doesn't switch. Is this possible? Thanks.
Hi, you can set up a video list with the camera inputs, with duration and type of transition and loop it. It worked for us. All the best, Tom
Hi, thanks for the response. I looked into this but don't see how that would do it? I don't want to alternate between two video files, I want to alternate between two live feeds from the cameras? I don't see a way in Lists to do this? Am I missing something? Thanks.
Rank:: Advanced Member
Joined: 10/26/2020(UTC) Posts: 76 Location: Maryland Thanks: 2 times Was thanked: 26 time(s) in 20 post(s)
Originally Posted by: Babbit Exactly, I used the wrong term, sorry. It is video list, you can set duration and all. Tom
