boulistenaute
#1 Posted : Thursday, April 1, 2021 1:23:40 AM(UTC)
boulistenaute
Unfortunately this camera does not find the right position when I use the function : Create Input at this position
Do you have any idea of ​​the problem? Is it possible to correct the positioning?
Thanks for your help, you can answer in French!
