Alchem
#1 Posted : Thursday, August 21, 2014 4:18:46 AM(UTC)
Alchem
Last time i've tried to connect 2 HDMI cameras to 4-input-port HDMI PCIe card (model DM626 V2) installed in my desktop PC. Unfotunatelly vMix recognized this card as one port/input. Is it possibly to use this card on vMix with more than one HDMI camera?
r@wisla
#2 Posted : Thursday, August 21, 2014 1:40:49 PM(UTC)
r@wisla
Was thanked: 40 time(s) in 37 post(s)
This card is not popular among vMix users.
I guess I found info about it:
http://www.dexatek.com/D...ture%20Card_eng_v0.2.pdf
Looks like the card is one channel only. You can plug multiple devices to it but only one will be supported by the card at one time.
PFBM
#3 Posted : Thursday, August 21, 2014 3:42:25 PM(UTC)
PFBM
Was thanked: 35 time(s) in 30 post(s)
get this one:
http://www.magewell.com/...mi_features.html?lang=en
works very well with vmix.
4 hdmi cameras at the same time .
long cable compensation
i got it working with a 80 meter hdmi active cable !!! 40m X 2.
Cheers,
PFBM
thecloudmediagroup
#4 Posted : Thursday, August 21, 2014 6:41:31 PM(UTC)
thecloudmediagroup
Was thanked: 78 time(s) in 43 post(s)
PFBM wrote:
get this one:
Cheers,
PFBM
This card works well. We have been using this in a live event IMAG and streaming setting and has worked great. It is not nearly as difficult to configure like the BMD cards are. If the input resolution and the driver resolution are not the same, the picture still comes through unlike BMD cards.
We are in the process of becoming Magewell distributors and should have availability soon!
-Seth
Innomedia
#5 Posted : Friday, August 22, 2014 2:23:15 AM(UTC)
Innomedia
Was thanked: 19 time(s) in 10 post(s)
We can also recommend YUAN 4-port cards (SC510-N4 HDMI or HD-SDI). They both work great in our live productions. You need an empty PCIe-slot (x4), install the driver and you are done. No trouble with different resolutions on each channel, no settings in control panels.
We have some cards in stock, if you are interested please mail to - karsten@innomedia-mick.de
Regards
Karsten
halfpipe
#6 Posted : Monday, October 13, 2014 2:25:16 PM(UTC)
halfpipe
PFBM wrote:
get this one:
Cheers,
PFBM
Fantastic Was it necessary to also use hdmi extenders or any special devices to achieve this length. Please describe if you have a minute Thank you very much
Bruce
