Systems
Basic system build
Joined: 10/20/2020(UTC) Posts: 4  Location: Galway Was thanked: 1 time(s) in 1 post(s)
Hi all,
Just building a new system for doing some vmix call, Zoom call via NDI, PowerPoint via NDI, Video and titles. RTMP streaming and recording will be used on this also. No need for instant replay for this build.
already have an Nvidia 1060 6GB GPU and may also get a decklink HDMI recorder for it also at some point.Also will add a 2.5g Lan port for a second connection for dante down the road.
Does the below set up ring any bells with you in what shouldn't be bought? The PC will also run some basic Premier pro at times.
AMD Ryzen 5 2600 Six-Core 3.4GHz Socket AM4 19MB Cache - Boxed MSI Tomahawk Max AMD B450 AM4 ATX DDR4-SDRAM Motherboard 16GB Corsair Vengeance LPX DDR4 3000MHz PC4-24000 CL15 Dual Channel Kit (2x 8GB) White Corsair RM 750 Watt ATX Power Supply - Black 512GB Kingston Technology KC600 2.5-inch Serial ATA III Internal Solid State Drive 1TB Crucial MX500 2.5-inch Solid State Drive Arctic MX-4 Thermal Paste Compound - 4g - 2019 Edition Corsair Carbide Spec 01 Midi Computer Tower - Black
Systems
Basic system build
