Virtual Sets, Where Color-Gradient-Box?
I am interested in trying to set up Virtual Sets for vMix. I have worked with Virtual Sets on both vMix and the TriCaster. I saw tutorials on YouTube about the creation of the graphics and the XML file that must be included. For adding in virtual video screens there is a Color-Gradient with two colors: Red and Green; the Blue channel is void. If I understand the tutorials correctly, by skewing this Color-Gradient-Box, the Virtual Set can change the aspect and skew of the virtual TV monitor screen in the Virtual Set. But where do you get a copy of this 1920x1080px (in 16-bit color) box going from Black-to-Green vertically and Black-to-Red horizontally? I made one in GIMP, but I am not sure if the horizontal gradation is linear. From a visual look, it appears that it is not linear from Left-to-Right. It does appear linear from Top-to-Bottom.
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: Cswa  For adding in virtual video screens there is a Color-Gradient with two colors: Red and Green; the Blue channel is void. If I understand the tutorials correctly, by skewing this Color-Gradient-Box, the Virtual Set can change the aspect and skew of the virtual TV monitor screen in the Virtual Set. They are called UV Maps. There is an old post where Marting provided one containing a fullscreen UVMAP: https://forums.vmix.com/...-UV-map-create#post10663or you make them : https://forums.vmix.com/...25868-UVmap-from-scratch
Thank you so much!! Yes, I know that they are called UV-Maps, but coming from Blender, I think of a UV-Map as something quite different. I guess they are related to Blender UV-Maps in an abstract way. Really appreciate your URL to the download.
I also thank you for the link to the GIMP tutorial. I used a somewhat different method to create the Virtual-Set UV-Map in GIMP. I will try this method also. Thanks again!!
