dmxxlr
#1 Posted : Monday, March 15, 2021 7:36:50 AM(UTC)
dmxxlr
Since I've got some free time between gigs, I decided to play with vMix 24 in my Twitch hobby.
I've found the border sizing is quite inconsistent. In the attached image, the source input (an RGB-modded Super Nintendo Jr) for the linearity test pattern is 720x480 coming out of a RetroTink 2x Linedoubler into a Magewell Quad HDMI. My pip is a 1080p source from my Sony A6300, also hitting the same Magewell card.
In this look, the game source's border is set to 6 for thickness, and the camera pip is set to 10. Yet the border around the game pip is much thicker in the preset shown in the attached image.
I've found some other weird bits where sizing is inconsistent. When I did a desktop capture of a twitch chat popout, the sides have a proper border, but the top and bottom were thicker..
Is thickness based on the source's resolution, or should it be standardized between layers?
Border Inconsistency.png (921kb) downloaded 1 time(s).
#2 Posted : Monday, March 15, 2021 12:20:33 PM(UTC)
Was thanked: 4708 time(s) in 1613 post(s)
Note the restrictions and limitations section below:
https://www.vmix.com/hel...putSettingsPosition.html
dmxxlr
#3 Posted : Monday, March 15, 2021 12:24:35 PM(UTC)
dmxxlr
Thank you. For the time being I will likely opt to bake in borders into a background, then overlay layers, as that will result in a uniform look.
