Feature Requests
Make Fullscreen output programable trigger and shortcut
Our House of Worship uses the Fullscreen function to turn projector slides on/off in sanctuary by setting the Fullscreen to "OUTPUT". The OUTPUT is sent to livestream at all times. We don't display the livestream service in the sanctuary but we display worship slides and videos to both livestream and sanctuary. The Fullscreen allows us to easily turn the projectors "on/off". It actually changes from OUTPUT to DESKTOP which when set to black screen appears to be off in the sanctuary. Due to copyright/licensing concerns, we have found it necessary to NOT show some song lyrics on livestream but still able to show in sanctuary. To do this we must reset the Fullscreen setting from OUTPUT to PREVIEW thus allowing us to show the slides in sanctuary while sending camera shot to livestream. Currently resetting the Fullscreen involves 5 mouse clicks to change the Fullscreen setting. For us that means 5 clicks before a song (set to Preview) and 5 clicks after the song (reset back to OUTPUT). Resetting the Fullscreen output with a shortcut would make this simple (one push button) to do while running a live production. Thank you for your consideration of this request
Rick
Joined: 10/26/2020(UTC) Views messages in topic : 76  Location: Maryland Thanks: 2 times Was thanked: 26 time(s) in 20 post(s)
Shortcuts already exists for changing the fullscreen outputs: Quote:Name: SetOutputFullscreen
Description: Change what is displayed on the Fullscreen output. Output,Preview,MultiView,Input Value = Output, Preview, MultiView, Input
Parameters: Value,Input
Description: Change what is displayed on the Fullscreen2 output. Output,Preview,MultiView,Input Value: Value = Output, Preview, MultiView, Input
Parameters: Value,Input You can also use a mix input and then pick that input for your fullscreen output. It gives you a mini switcher of sorts and the ability to do nice transitions independently, just like an M/E on a traditional switcher. This is the way I would prefer to handle it in a production setting.
Feature Requests
