Is there a way to add some transition on UTC. Like one team make a point or goal and you change the value of the score, is it possible put a transtion to make that change smoother and cooler? Thanks!
Originally Posted by: Gabriel Mewes  Is there a way to add some transition on UTC. Like one team make a point or goal and you change the value of the score, is it possible put a transtion to make that change smoother and cooler? Thanks! Yes but at the side of the title not the UTC
