Zixi Input into vMix using VLC for vMix
Joined: 8/15/2013(UTC) Posts: 108   Location: Could be Australia could be Europe/UK! Thanks: 2 times Was thanked: 9 time(s) in 9 post(s)
Been playing around with Zixi, pretty powerful stuff.
I was able to get a Zixi feed into vMix using VLC to convert it to NDI, but I would prefer a direct input into vMix from the Zixi output.
1. Install the Zixi plugin to your normal VLC install.
2. Copy the plugin files "libaccess_zixi31_plugin.dll" and "libaccess_zixi31_x64_plugin.dll" from C:\Program Files\VideoLAN\VLC\plugins to C:\ProgramData\vMix\vlc64\plugins (note C:\ProgramData\ is a hidden folder, if you paste it directly into the Finder window you can get there)
3. Add stream in vMix, for me it was "zixi://127.0.0.1/TestRTMP"
Hope this is useful for someone. Keen for a better way to get a stream out of vMix to feed to Zixi...
