johnbosch
#1 Posted : Friday, February 26, 2021 1:53:06 AM(UTC)
johnbosch
I have created multiple live inputs into VMIX, and setup multiple color inputs where i have added a multi view, this will generate a live multi viewer on the (broadcast FEED / Display)
What I would need is to generate labels for each input that will be visible in the broadcast feed. as each input will represent its function such as skype, NDI input and live cameras (SDI)
Is there a easy way to do this?
obviously there is a way to create a tile, but that's not linked to an input, but an overlay to the output which will not change if my input are changing.
Who can point me into the right direction.
John
#2 Posted : Friday, February 26, 2021 2:01:03 AM(UTC)
What about a title layer on each live input containing it's own info ?
Else some clever scripting checking the content of the muliview feeding the info to your general title ?
Joeboe
#3 Posted : Friday, February 26, 2021 3:20:12 AM(UTC)
Joeboe
I do not understand what you really mean by a label, but I label all my inputs with what I want to know at sight...do not know if this is what you want, but if you click on the "COG" wheel for each input, and use the "GENERAL" Tab, you can rename the inputs....hope this is what you mean
