Parr_San_Gia
#1 Posted: : Wednesday, February 24, 2021 7:11:42 PM(UTC)
Parr_San_Gia
Italy
Buongiorno.
Sto iniziando a utilizzare vMix. Ho usato già da alcuni mesi OBS. Il problema o difficoltà che riscontro con vMix è nel creare SCENE diverse e memorizzarle.
In OBS creavo scene nuove e poi inserivo le varie "sorgenti" audio e video e venivano memorizzate. Bastava fare "cambio scena" e mi ritrovavo il tutto come lo avevo preimpostato.
Come si fa in vMix a fare la medesima operazione?
Grazie per vostre risposte chiarificanti.
ZdRS
Good morning.
I am starting to use vMix. I have been using OBS for a few months now. The problem or difficulty I have with vMix is ​​in creating different SCENES and storing them.
In OBS I created new scenes and then I inserted the various audio and video "sources" and they were stored. It was enough to "change scene" and I found myself everything as I had preset it.
How does vMix do the same thing?
Thanks for your clarifying answers.
ZdRS
