mundm
#1 Posted : Monday, February 22, 2021 6:30:08 PM(UTC)
mundm
Germany
I use 1080i50 projects on three different vMix Systems.
On each of them I get audio delays in interlaced projects on the internal recording and the external output between 1-4 Frames (40 - 140ms).
The used test signal is not lipsync any more.
I use Blackmagic Capture Cards and AJA I/O 4k Plus on different Systems. There is no problem on the recording in Blackmagic Media Express (0ms) or AJA Control Room (3ms).
There is no problem with vMix in a 25p project.
Does anybody else have this Problem?
What was your solution? Working in progressive projects is not possible for us.
