Hay algun tutorial de como agregar set virtuales personalizados a los.predeterminados de vmix corre
Hola alguien sabe donde hay un video tutorial de como agregar set virtuales en los predeterminados de vmix y que al agregarlos en el input quede con la vista previa de como se crearon?
Hello, does anyone know where there is a video tutorial on how to add virtual sets in the vmix defaults and that when adding them in the input it will have the preview of how they were created?
Joined: 12/27/2012(UTC) Posts: 5,500  Location: Belgium Thanks: 314 times Was thanked: 1020 time(s) in 838 post(s)
Put the virtual set folder in the Virtualsets folder within the vMix install folder
C:\Program Files (x86)\vMix\VirtualSets Make sure it contains a thumbnail.jpg being a "screenshot" of the virtual set
Many would appreciate posting in English first including the description,tnx
Joined: 3/7/2012(UTC) Posts: 2,683  Location: Canada Thanks: 33 times Was thanked: 512 time(s) in 480 post(s)
@ Diego Iluna
The biggest "danger" with putting new custom files into a vMix folder is that you will potentially lose it with the next vMix update and the folder is overwritten... Just my thoughts.
Joined: 10/6/2020(UTC) Posts: 98  Was thanked: 21 time(s) in 21 post(s)
Originally Posted by: IceStream  The biggest "danger" with putting new custom files into a vMix folder is that you will potentially lose it with the next vMix update and the folder is overwritten... Updating vMix restores any of the default Virtual Sets that have been moved or deleted, but my custom virtual sets have survived a few updates, and even a de-install/re-install of vMix, so I think it's pretty safe.
