nowski
#1 Posted : Tuesday, February 16, 2021 11:36:21 PM(UTC)
nowski
Ok I have set up the controller to work for the usual PTZ controls, however I want to have more than one PTZ, how does one set the destination of the Xbox controller to be the "right" camera? Is there a way to activate PTZ control for a specific input?
It seems obvious, but I can't see the solution anywhere.
edit - I see you can apply it to the active input, preview input or hover (mouse over input) - thats handy.
What I am actually doing is using it to adjust split screen shots.
If I have a 3 way vmix call, I can convert a virtual input to a PTZ shot, then use the Xbox controller to easily frame the shot within the split as doing it via position is very fiddly - especially when live!
#2 Posted : Wednesday, February 17, 2021 12:42:04 PM(UTC)
@ nowski
Setting the target Input as the one that is in "Preview" is probably going to be the most practical and versatile option (and generally why the X-Box Shortcut Template is set to that), but YES, you can set it to be a specific Input if you want, just select it from the Input Dropdown menu when setting up the Shortcut.
