Dropdown limited for MIDI device selection
I noticed that if I have a lot of MIDI devices, the dropdown list for selecting the MIDI device (for shortcuts) does not show all devices. I have to disconnect several devices and then the device I want select is on the list. I can then re-connect my other devices and all is fine so I think there is a bug in the select MIDI device dropdown list under shortcuts. So at least I have a workaround but was not sure if anyone was aware of this issue.
Note, the reason I have so many devices is that I have many "virtual" devices using Bome Unlimited Virtual Port and BomeNetwork or LoopMIDI virtual pipes.
This is on Windows 10
